Allen Bradley 1747 SDN configuration via SLC503 CPU
Buscom
Jul 2013
paris
78
Hello,
Please , I need help,
I want to configure a DeviceNet network. Indeed , my DeviceNet network consists of : 1747 SDN Allen Bradley, SLC503 CPU connected to a frame, a CDN066 module for converting RS232 to DeviceNet and communicating with the electronic map in serial port.
I have a 1747 CP3 cable who make the connection between my PC and the SLC503 via the RS232 port for programming the CPU. I have RSNetWorx software to configure the DeviceNet network.
When I'm in RSNetworx and I add the 1747 SDN after configuring the driver in RSLinx , I can go online , but I still have this message displayed "Online not browsing" and on the 1747SDN LED, there is only the lED of the "module" button turns red . the LED of the "NET" button does not light up and the same for the LED Module CDN066 they do not light up .
What does " Not Browsing ?" In fact , the only connection there is between the SLC503 and my PC is a 1747 CP3 cable . do you think it is not enough to configure a DeviceNet network in RSNetworx ? I still need to buy the 1770 KFD for this to work ? In fact, I thought the 1770 KFD since , but what happens is that I do not want to establish a DeviceNet communication with my PC and SLC503 , but just between the PCB and the SLC503 by programming on PC . this is why I did not buy the 1770 KFD . But rather the CDN066 to convert RS232 to DeviceNet.
How can I configure the DeviceNet Network via the SLC503 CPU?
Thank you for your help.
I am trying to update the firmware of a 1747-SDN Series B that is currently at firmware version 5.01 to version 8.006 which is the only version...
6,242
We have a number of 1747-BSN modules in stock but need 2 1747-SN modules for a project. Can we use a 1747-BSN in lieu of a 1747-SN? Any...
1,674
I have a AB 1747-UIC USB to DH 485 converter Can I use that to connect to a watlow controller EZzone with "standard bus EIA 485" ...
1,877
Hello Everyone, Im struggling with a plc that we got here in the company where I work at. We use this plc for precooler temperature monitoring...
3,645
hello, I want to make a DeviceNet communication between Allen Bradley SLC503 and a PCB card, I want to know if in addition to the 1747SDN, is...
3,332
