plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old September 13th, 2019, 02:16 PM   #1
ganutenator
United States
ganutenator is offline
ganutenator's Avatar
Anyone a permanent magnet motor expert here?
I can't seem to increase torque to the desired level w/o the motor just sitting there shaking itself to death.
I can only get 80 foot lbs after the 30:1 gear box.
1/4hp motor
1/2 hp Toshiba drive
Auto tuned
Yes, the motor is rated at 239 inch pounds of torque. And after the gear box that equals 80 foot lbs, but come on.
Why does it shake itself to death when I raise the torque limit of the drive up from 200%?
The asynchronous motor had much better torque.
I thought IPM motors were supposed to produce more torque.
Was I mis-informed?
Old September 13th, 2019, 02:42 PM   #2
Phil Buchanan
United States
Phil Buchanan is offline
Phil Buchanan's Avatar
Sounds like it's not producing a smooth output in response to torque command and that's normally a feedback problem.
Can you run a trace on the output using the drive/drive software to see it's response to torque command changes? I possible that may show a clear picture of what's happening.
__________________
PLC Boot Camp Training
VFD Training
HMI Training
Electrical License Prep Training
Motor Controls Training
http://www.KeyAutomationTraining.com
Old September 13th, 2019, 02:43 PM   #3
AustralIan
Germany
AustralIan is offline
This may be why it is shaking itself to death http://www.plctalk.net/qanda/showthread.php?t=121963
Old September 13th, 2019, 04:21 PM   #4
jaden
United States
jaden is offline
I would question that a 1/4 HP motor is capable of delivering 20 Ft. Lbs (239 Ft Lbs.)
Old September 13th, 2019, 08:08 PM   #5
kamenges
United States
kamenges is offline
kamenges's Avatar
If you are getting 80 lb-ft of torque after a 30:1 reducer you are producing 2.67 lb-ft at the motor, or 32 lb-in. Even that is high for a 1/4 HP motor unless it is a higher pole count motor, something like 8 or 12 poles.
Is this a PM synchronous motor that you are running open loop?
Keith
Old September 13th, 2019, 08:19 PM   #6
jraef
United States
jraef is offline
jraef's Avatar
Has the Tosh drive been qualified to operate a PM motor? All of their newest drives like the AS3 and S15 are, but if you go back just one generation, they are not.
Old September 13th, 2019, 10:13 PM   #7
ganutenator
United States
I'm running it in PM mode
Old September 13th, 2019, 11:25 PM   #8
ganutenator
United States
It is actually running quite smooth. But the customer is concerned about the lack of torque.
It only becomes unstable when I increase the torque limit above 200%.
But that seems weird, because, at 200% it is producing 100% torque.
Old September 15th, 2019, 06:33 PM   #9
Gene Bond
United States
Gene Bond is offline
1hp, 1800rpm = 3ftlbs (36inlbs) of torque, so 1/4hp = .75ftlb (9inlb)... (assuming 1800rpm base speed)
x30 (for the reducer) = 22.5ftlb (270inlb)
Old September 15th, 2019, 06:43 PM   #10
ganutenator
United States
You all crack me up
Old September 15th, 2019, 07:28 PM   #11
Gene Bond
United States
What's the base speed of the motor? or pole count?
Old September 16th, 2019, 11:35 AM   #12
kamenges
United States
kamenges is offline
kamenges's Avatar
Quote:
The motor is only going to draw what is required to control the load, on average, regardless of the torque limit. The instability when the torque limit is 200% is likely the result of having the torque available to actually follow the output of the velocity controller, which is tuned too tightly. If you require 100% torque to move the load and you are applying a 100% torque limit the drive is probably buried in torque limit and the tops are getting chopped off the velocity loop output.
Keith
Old September 16th, 2019, 04:31 PM   #13
AustralIan
Germany
Does figure 3 help you?
https://library.e.abb.com/public/886..._lowres_v2.pdf
Figure 1 is probably the dol curve they're used to.
Does your motor manual/specsheet tell you any points on the torque curve?
Old September 17th, 2019, 07:52 AM   #14
Gene Bond
United States
Apparently none of us understand where the problem actually happens.
Is it when you overload the motor, or is it while you are running within the motor continuous rating?
IMO, running an open loop PM motor above 100% torque is asking for trouble. Closing the loop with an encoder (servo motor), 300% is no biggie. Open loop, you are running the motor as a stepper, and we all know what happens when you overload a stepper motor.
Old September 17th, 2019, 09:09 AM   #15
ganutenator
United States
I guess the only problem is that the customer is concerned that it produces only 80 ft/lbs of torque after the 30:1 gearbox when the torque limit is set at 200% of the drive rating. (p.s. the motor and gear box claim that 80 ft/lbs of torque is 100% for the motor and gearbox)
The drive defaults to 250% for the torque limiting parameter F441 (Toshiba is calling that as being disabled). But, when I run the motor that way, it just tries to shake itself to death. When I remove the run signal from the drive, it doesn't stop (w/ parameter F441 at 250%) the drive. I have to power down the drive to get it to stop. Customer is worried about that too.
What does happen when you overload a stepper motor?
1800 is the rated rpm
The ipm motor has 4 poles.
The drive is 1/2hp, the motor is 1/4hp.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Permanent magnet dc servo roxusa LIVE PLC Questions And Answers 3 June 7th, 2018 03:33 PM
Anyone used permanent magnet motors with VFDs like ABB ACS355/ACS800 Pete.S. LIVE PLC Questions And Answers 16 April 15th, 2016 07:02 AM
Permanent magnet synchrone motor Jeff23spl LIVE PLC Questions And Answers 8 April 22nd, 2010 11:36 AM
OT: Permanent Magnet Motors paraffin power LIVE PLC Questions And Answers 4 November 28th, 2007 12:26 PM
Permanent Magnet AC Motor JamesWSY LIVE PLC Questions And Answers 2 October 4th, 2005 09:55 AM
