IPM motor w/ VFD in Sensor-less vector mode?
ganutenator
May 2002
kansas
1,440
There is a Permanent Magnet mode for the vfd, but it seems to run much better in sensor-less vector mode.
Anyone know if this will harm the Internal Permanent Magnet motor?
We use dc injection in our synchronous motors to raise the motor windings 10 deg. above ambient. If we do this w/ a permanent magnet mtr, will it...
1,145
Hi everyone, I have a AB Powerflex 753 powering a simple 480V permanent magnet motor using flux vector control (I believe it's the only control...
1,344
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
186
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
141
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
341
