Hi guys,
This is not typical automation question or discussion, but I believe that it could be asked here.
For my next job I need to find some solution for main electrical room in compost production factory. Main problem is dust; it’s very small so it finds mysterious ways to get in room. Dust is very clammily and aggressive so frequency converters inside have died few times (bad luck said that need to be more expensive one ABB ACS 800 and Omron E7).
Next problem is ammoniac. Compost dust is full of it and on temperature in room it depart from dust and really smells and hurts eyes so electricians can’t work inside.
In principle, I know what I need to do. I need conditioning air to put down temperature and wetness of air. Next, I need to pump clean air inside and to pump it lower in the room and need to press out higher air because air is heavier that ammoniac.
What I want to ask you here is have someone has similar experiences? Some tips n trick are very welcome; maybe some original solutions or at least some discussion.
Best Regards
Lesa
Best Regards
Lesa
