Karolewsky
Hi all,
Do anyone of You guys use the S5 programmeradapter 798-0CA00-0AX0?
I have no expierience with S5. However I need to update an S5 program from my S5 PLCs into my PG and make some backups. I have Field M3 with a S5 adapter which i can insert in the memory card slot of my Field PG. However I faced some problems. When I insert the module i have no indication on my computer that I inserted a slot and connected an eeprom card to it. I tried to use a S5 eprom software that is already installed, but I got error 900, that seems it can't see any eprom card connected. I have no other chance of updating the program, because of the maintainence works on my plant, there is the power supply off. Also can't find any manuals for the S5 programmeradapter. I have only a small leaflet with info that after a correct card insertion i should see some indication. But I don't see it.
Could anyone help me with some clues and tricks on how to use the adapter correctly?
Greets to all
Greets to all
