cables for simatic ti 305
godfather
Jan 2020
oregon
Could someone help me get the proper communication cables for a siemens simatic 305 with a dl340 cpu . im a 30 plus year electrician and very little experience with programming but I have the ability to use them to troubleshoot. our programmer is no longer with us so im in a spot.. Thank you guys in advanced.
This unit started life as a Koyo Kostac in the early 1980s. It was them marketed as the General Electric Series One. After that it became a Texas Instruments TI300 series. Siemens absorbed TI so it then became Siemens Simatic 305.
It is still available from Automation Direct and the software and interface cables are available from them.
www.automationdirect.com
DirectSoft 5 from Automation Direct works with your hardware.
Check out their web site in order to find the right cable, not sure if they still sell them.
I've worked on a couple of those years back.
Hope this helps.
Hi everyone! I am looking for some cables to connect an OP27 to a PC, both for the IF1 Interface and the IF2. Does anybody know what kind of...
3,951
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
178
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
104
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
158
Hi all, I wonder what's the best type of cable to use for RS-485 2 wire + GND That is, Data+, Data- & GND I know that Belden 9841 (not...
1,067
