Simatic OP27 IF1 & IF2 Cables
olatz.recio
Jul 2007
London
Hi everyone!
I am looking for some cables to connect an OP27 to a PC, both for the IF1 Interface and the IF2. Does anybody know what kind of cables I should be looking for?
Thank you in anticipation.
Best regards,
Olatz.Recio :nodi:
IF1A and IF1B are used for the online connection to the PLC.
The pinout is totally dependent on which type online connection you intend to use.
IF2 is used for download from a PC to the panel (and sometimes for attaching a printer).
For IF2 PC-to-OP27, the cable type # is: 6XV1440-2KH32
On the 15-pin OP plug is noted: "TD/OP V.24". Insert in IF2 port on the OP.
On the 9-pin PC plug is noted: "TI505/PC V.24". Insert in serial port on the PC.
Or Do it yourself description:
OP plug:            PC plug:
15-pin male 9-pin female
pin 1 shield ------ pin 1 shield
pin 3 RxD ------ pin 3 TxD
pin 4 TxD ------ pin 2 RxD
pin 12 Gnd ------ pin 5 Gnd
pin 1-6-4 jumper
pin 7-8 jumper
Notice: This is for a standard 9-pin serial port in a standard PC.
If you have a Siemens PG, then the cable is not the same.
Hi, I'm working on a machine with these two HMI screens, but we do not have any back up. I believe it is possible to take a snap-shot of the...
6,726
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
96
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
174
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
312
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
323
