PV550 Issue
workemailboca
Jul 2011
Florida
Cannot see PV550 using 1747-PIC. Originally was able to when downloaded program to PV550. Now the RSLINX cannot see unit. RSLINX and 1747-PIC is O.K. because it recognizes the old PV550 but not the new model PV550. Replaced a older PV550 with a failing backlight with a new model w/o backlight. Remember I orignally was able to communicate with new PV550 before download. The new PV550 does communicate with the SLC 5/01 processor.
Since it's communicating with a 5/01 controller it has to be a DH-485 unit, but of course there are four different models that support DH-485, so the general requirement to "post the whole part number".
My guess is that either RSLinx is set up as the name node number as the PanelView (so that they conflict) or there's a "maximum node number" setting that limits the browsing of the network.
I believe that PanelView terminals come out of the box as Node 2 on DH485. Their actual runtime node address is configured in PanelBuilder32.
Good Morning Folks. Win Xp, PRO, Version 2002, SP3 RSLinx Classic 2.54 Using the AB UIC-485 driver with the 1747-UIC and a 2711-NC13 connected...
1,217
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,221
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,664
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,856
Trying to write a program for a PV550 (2711-T5A16L1, Ser. B, Rev. E, FRN 4.46) to test the touchscreen. I wrote a program with 16 pages and on...
1,690
