What's your favorite obscure tools you have? (Software or Hardware)
I don't know that I would consider these apps "Obscure", however I did a job for an OEM this year and they had Excel tools for just about anything. The 2 I used the most were a Hirschmann switch configuration tool and another Excel tool that would completely create a V. 32.02 program with HMI logic, conveyors, footprints (stations) all the data logic, tags, AOI's UDT's--everything. It was really cool. You just selected a processor from dropdowns, chassis size, conveyor, how many stations and I/O blocks and BOOM! you had a program. I was sitting messing with a traffic light program I wrote just to keep my navigation skills sharp.
789 Process Meter. All the functionality of a high quality multi-meter, with the added functionality of sourcing 0-20mA to a PLC input, etc. Maybe this isn't "obscure" tool, but I don't see many of them around. I use mine quite frequently for the 0-20mA sourcing function. I lend it out a LOT to our maintenance guys.
Knipex Universal stripping tool, Part# 16 95 01
Great for stripping off the insulation of cables. Note: It does not work well, or at all, for small diameter cables (< ~6mm diameter). But anything larger than that, it's a must have. Has added functionality for stripping wires, etc, but I use it exclusively for stripping insulation and/or disassembling of cables.
Probably not obscure at this point, but the Knipex Pliers Wrench is insanely handy, great replacement for an adjustable wrench. For those who don't know about them, the jaws open parallel instead of opening like a pair of Channel Locks, and they have smooth jaws so they don't mar surfaces. They also have an 11:1 mechanical advantage so the jaws grip much harder than you have to squeeze. Great for instrument techs working on Swagelok fittings.
Looks very handy! Knipex makes great tools! Love their stuff.
Obscure and obscure..
Even though i have MS Office i tend to use LibreOffice quite alot, especially Calc and Draw. Calc for example has a better csv file handling than Excel imo. And Draw is fantastic to draw quick flow charts, P&ID's, making graphical pdf documents, just to name a few.
The real stand out feature in Draw is the ability to open PDF documents and edit them, for example old circuit diagrams where native DWG's are not available (not scanned though afaik sadly).
Hardware wise i love my Leatherman Supertool 200 when i dont have access to the whole array of ordinary tools.
Wireshark (already been mentioned).
Advanced IP Scanner (useful because it returns MAC addresses) or AngryIP Scanner (more obvious which IPs are open and which are not) for scanning a whole range of addresses.
Greenshot (already been mentioned).
SharpKeys to map right alt key to insert. This way I can work on any customer's dev environment and not setting up hotkeys in Logix Designer is less annoying. Just hit right alt and type the instruction. Anyone who works on a lot of customer's dev machines for Rockwell PLCs, this is a huge QOL boost.
I used to use Angry IP Scanner quite a bit..
Now I am sold on Slitheris Network Scanner by Komodo labs..
You will be stunned at the data it returns. Free for less than 50 devices, but I never had it care if I scanned more than 50 devices.
https://www.komodolabs.com/ip-scanner/
Thanks Nathan, I'll check that out.
For me, AngryIP still is mega useful to scan entire networks to find potentially open IPs. It's great for customers who want to add some Ethernet devices but their documentation is non-existent.
I will second Slitheris Network Scanner! Having used Advanced IPS and Angry IP for years I was introduced to Slitheris about 3 years ago and have never looked back. It's one of those tools that just works well....
I am looking for something.
Anyone know a brand/type of a multikey for opening diverse types of electrical enclosures ? You know the ubiquitous (Rittal ?) type but also with square, triangle inner, triangle outer, ...
I keep losing mine. I need to get a good one and then attach it to a chain.
Thanks !
I spent half an hour browsing on our suppliers web portal with no luck.
Search for "00 11 01 KNIPEX", and there you go. I will get one for myself and for my closest colleague as a christmas present.
I've been thinking about grabbing one of these for a couple of years now, they look pretty neat.
I thought it would be fun to ask what everyone's favorite cheap-er HMI is and favorite features. My favorite features are how easy are 1)...
1,189
Who's using MQTT to send/receive datat out of PLC's/Machines out there and if so, what is your favorite or "go-to" gateway? We've been using the...
2,782
Looking to step away from the PVP hardware but not AB software. Its what customers request so thats just not usually an option. Wondering what...
3,300
I’ve been using ACADE for a bit and I feel like there has got to be a better more effieicent option out there. Is there? Or am I just slow in ACADE?
79
50,620
Ive been looking at some of the Automation Direct Absolute encoders that they offer (Koyo brand) and was wondering what everyone else uses in...
1,900
