Favorite brand absolute encoder?
JZerb
Oct 2016
Here
423
Ive been looking at some of the Automation Direct Absolute encoders that they offer (Koyo brand) and was wondering what everyone else uses in their projects?
We had machines that used a few Omron encoders on each in service for 10 - 15 years. I recall only one failure that wasn't a damaged cable. I wouldn't hesitate to use them again.
I've inherited Allen-Bradley & Sick absolute encoders over the years - no qualms with either.
I don't presently use AD but in a prior job I had good results with their stuff.
returning to this. Ive since got an AD absolute encoder wired into a 1762-IQ16 and have gotten it setup in the logic so that it takes the Gray code, converts it to binary, then takes that binary and can show where in the 360 degree rotation said encoder is. My only gripe with this encoder is that there is no SET ZERO pin on it, as there are on the AB absolute encoders that ive used in the past. I can probably do it within the logic, i just havent sat down and hammered it out yet. Im going to look into the other names mentioned above though and hope that they perhaps have the SET ZERO option.
Originally posted by Peter Nachtwey:
We link any brand of encoder that sticks to the SSI specifications.
If JZerb is wiring this to an 1762-IB16 its not SSI. It is multi-bit parallel. While natural binary or Gray code doesn't matter much with SSI it certainly is more friendly with multi-bit parallel.
Keith
What Opto Isolator brands do you like to use, and where do you get them? What are your favorite modules? Any undesirable failures or "premature...
6,050
I thought it would be fun to ask what everyone's favorite cheap-er HMI is and favorite features. My favorite features are how easy are 1)...
1,170
What do you guys have in your bag of tricks? For software, my favorite is definitely PDF-XChange editor. There's a free version which has by far...
105
74,567
Who's using MQTT to send/receive datat out of PLC's/Machines out there and if so, what is your favorite or "go-to" gateway? We've been using the...
2,761
Looking to step away from the PVP hardware but not AB software. Its what customers request so thats just not usually an option. Wondering what...
3,274
