RBergmann
My system is a PV1000 Plus with SLC 5/05. Using RSView ME V4.00 (CPR 7)and RSLogix 500. Similar hardware configuration to other projects I have worked on using the same software.
I export tags from RSLogix 500 to an .EAS file for import to RSView. Tags show up when I click HMI Tags->Tags in the RSView Explorer window (side bar). So far so good, this still works.
In RSView, until recently, when I clicked on an object's Properties->Connections->Tag (...), I would get a screen to select the tag I needed. Just as I'm supposed to.
HOWEVER, now when I click Properties->Connections->Tag (...), the program appears to be searching and then locks up and I can only exit using the three finger salute (Ctl-Alt-Del). I've reinstalled all components in RSView.
I should mention that I renamed my computer since the last time I used RSView and the name was problematic for a while, but this never prohibited me from using the program and only caused an issue when I tried to download the project. After correcting the naming issue (found a solution on-line), is when the Tag Browser issue arose. All other functions work as before.
Any ideas?
Any ideas?
