GE Fanuc 90 30
ngilbert
Oct 2017
Ohio
28
PLC lost program over the weekend a few times and we changed the battery but we were still losing the program. Ordered a new power supply and installed it with a new battery but we are still getting a red light on the battery. Any suggestions? Even tried it with some old power supplies with new batteries but same issue, red battery light is on.
when you say you replaced the battery with a new, do you mean a "new" battery from your stock that's been sitting on a shelf for 10 years? Batteries have a shelf life. Try putting a meter on your replacement battery to see if its still good
Ran into this a few times on older 90-30 systems..
Could also be...CPU, Power Supply or Backplane problem..
What CPU are you using?
Looks like it is a IC693CPU340
We have an old backplane laying around that we were going to try next. Batteries have checked out good.
Since the battery is located on the power supply module and the RAM memory it maintains is on the CPU module, there needs to be a complete circuit between the battery and the CPU. Since you've already swapped out the power supply, the other possibilities are the backplane and the CPU module itself.
I have a CPU331 and a CPU363 which have a place where you can connect a battery directly to the module. I expect the CPU340 does also. Remove the front cover of the CPU module to get access to it.
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
109
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
110
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
102
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
170
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
215
