Click Plc/analog 0-10 v output module/0-10v dimmable led driver
R.Como
May 2020
Montreal
Click Plc/analog 0-10 v output module/0-10v dimmable led driver.
I made a program using multiple drum to create by increment fade in and out led control. Works fine but i am wondering if there is another way to do this?
What is your input or whats telling the LED to dim? I know your program but why? whats the reason or application?
Everyone I have done similar I had a potentiometer as my input
And welcome to the forum :site:
As an exemple,I could have different inputs with different led dimming paterns.Application mostly museum enviroment
If the drum is working then there is nothing wrong with it... but you can also have an array stored with values then move that value to your output word
For an example, the trainers I sell have a Pot and Meter, I move the input from the pot to the output on the meter... so if someone moves the pot to 25% then the meter also moves to 25%, so if you are using this for learning try getting a analog input also, then try doing the same
I need to change my program to increase a IP transducer by 0.5 psi every 5 seconds. I am making a automated pressure tester using a pump, IP...
1,064
Hi All I'm trying to add an analog input module to my Click plc to attach some potentiometers to. I can't seem to get any data in my system...
2,011
Hi all I am trying write a program that has analog input from a pressure sensor in a tank that read the pressure sensor for level when the pump...
6,622
I'm reading Modbus data over TCP from a remote I/O device with an HMI. i'm reading it into an UNSIGNED INTEGER tag Modbus 40001 = Input 1 Modbus...
1,942
I have an Automation Direct Click PLC (C0-02DD2-D) with a 24 VDC power supply. I want to make a variable input device to supply the analog input...
3,688
