Steve Bailey
It looks like you are trying to enter variables wherever the software is calling for IP addresses. You need to enter actual IP addresses. The same applies to produced EGD exchange IDs.
At some point you will need to make the EBI target the active target and transfer the hardware configuration to it. The software will call that action a "download".
You will also need to make the PANEL target the active target and perform a download and start operation to it.
The project I posted in #7 I is very similar to what you have done except that I used my laptop as the PANEL target instead of a Quick Panel. That project worked. Compare my settings against yours.
