GE Versamex IC200EBI001 Fault Table Codes 9
zeroman
Aug 2019
perth
I am setting up a new GE Versamax drop with modules as below:
-IC200EBI001
-IC200PWR102J
-IC200CHS003M
-IC200MDL742H.
However, I find that I am not able to send an output LED to light up in the MDL742H. There is only LED to indicate OK. So, I used my diagnostic logic and it indicate Fault Code 9 which is 'LOSS_OF_USER_POWER_FAULT'. Anyone know what's that fault code mean?
Hi Steve,
Thanks for the reply, eventually i found out that day. I realised that you need field power source to drive the DO output. Thank you though
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
65
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
97
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
148
Hi, Experts: We have 20 + years old GE PLC series 90-30 stop running (the run led not on and battery led not on) and HMI showing that "PLC has...
198
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
