TIA portal: creating UDT and assigning variables to them
Ashebl
Jan 2016
Cairo
I am using CPU 315-2 PN/DP which doesnt allow to assign the variables to the created UDT , meaning the created UDT"PLC Data type" doesnt show in the drop down list of the varaibles tables when i try to create a varaible and assign it to this UDT.
Is there a workaround to this?
My target is to move varaibles created in a data block from the DB addressing to the I/Q addressing area so that I can define them in the transfer area of the I-slave communication to be exchanged with another Master DCS.
Thats why I thought of moving them through a variable of a deined data type so that they get the adresses automatically instead of assigning them one by one,
What if i have so many variables of different data types but they are all in the same DB and i want to do the same for each one.
Is there a way that can assigns addresses automatically
I created a UDT and it appears in the drop down list when I populate a DB. Is this what you want to do?
I want to do the same but with a variable not a datablock because i want to map the IOs to Q addresses not DB because they will be exchanged on profibus.
If you try to configure the transfer areas in the I-slave communication, you will find that it takes only I/Q addresses not DB
I have around 500 IOs of different types and they are all defined in a datablock already, but i was thinking of an efficient way to assign them the addresses from Q area at once instead of doing it one by one.
Hello, As a person who is not that experienced in plcs i am new to a lot of things in this environment. Today my problem includes the alarms...
1,373
Hello everyone, As you can see in the screenshot below i have some values that are retentive. Now i want to create a specific value for specific...
1,509
Hi Experts, I have created a face plate and to make the objects on it visible and invisible for this i created a tag Bool called Show hide Face...
2,385
Hello I'm looking for a way to do the following but i don't know if it's possible.. I use Wincc TIA V15 comfort panel i use the recipes as...
3,574
Hi, If I were to create an INT for my FB / DB, will this use up a whole DINT every time I use one or will is just use an INT's worth of memory...
1,874
