GE FANUC 90-30 IC693ALG442 Input Output Refrence
%AI0009 - %AI0012 are only used in the program block named "PSUMNTR", and in that block only used to drive -(/)- coil instructions which aren't referenced anywhere else in the program
%AQ0001 is used in the program block "METERS", where it gets its value from %R00063. %R00063 is not referenced anywhere else in the program, and may be written to via the Modbus link. Based on the numbers in the scaling equation in "METERS", the range of values in %R00063 is zero to 5000.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
68
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
145
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
134
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
125
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
210
