AB powerflex 525 drive runs but motor doesn't turn
FriendlySteaK
Jul 2020
Highland
Hi all, I have a powerflex 525 where there is no voltage coming out to the motor. The drive was reset to factory defaults with stop and saftey jumpers in place for testing purposes. The drive fan comes on and the control panel shows the hz ramp up but there is no voltage at the u v w terminals. No faults displayed
Would anyone know what could be wrong?
That's an interesting problem. I will assume that it is set to V/Hz since if it were in vector mode it would give some sort of error. In V/Hz mode the drive puts out the voltage and current according to the programmed ramp but doesn't really measure much for feedback. The only thing I can think of is over-current.
No output at all. Do you have a motor connected?
It should show at least a couple of volts in that case .. but maybe the frequency is low enough that it would fool the meter into switching between AC and DC measurements?
You say the frequency ramps up .. so I guess the motor is not a short.
Never mind - I guess I don't have anything intelligent to say!
The motor is connected and works using another vfd, there is voltage at the dc bus, the controller should fault if voltage is to high/low
Drive in default v/hz control
When pressing start command, Controller displays the hz ramp up and change depending on where the onboard potentiometer is set
you can actually have problems with pf525 if the load is too great on startup, and it will limit your output with a sustained HZ. essentially looking like a bad motor/drive.
you might try looking into parameter A495. I've seen erratic operation from 525 and 4m drives when the load was too much to allow it to run properly, but not restricted enough to cause an overload condition.
That and possibly upping the current limit to see what happens with it (A484-A485)
Hello, were you able to fix this error. I have a 525 with the same problem.
V/hz control, VFD starts, HIM shows output voltage and output frequency, but I have no voltage at UVW.
Without connecting the motor
Double check that your S1 and S2 jumper is correctly terminated. If you clamped onto the insulation it will look like it is installed but there is no connection. That input is a base block, it disables the transistors.
Look at b006, bit 5. If it’s high, the S1/2 circuit is active. If not, it is not continuous.
Hi maybe do you know what part is broken, power board Firing board or IGBT or control board ?
Regards and thank u for the answer
I had to replace 3 PowerFlex 40 multi-drives that each had 3 PF4M daisy chained off the DSI port. The PF40s had comm-e cards installed for...
2,426
Hi I have a powerflex 525 that is connected on ethernet to a compactlogix and is on ADC , I have just changed a setting on the drive and if I...
1,816
I have a machine with a CompactLogix ver20 and PowerFlex 40 multi drive node. That PF40 has a Comm-E ethernet adapter and has four PowerFlex-4Ms...
1,887
So we replaced a PowerFlex 525 drive with the exact same model. I was told that once it is in and given the old IP address, you can upload the old...
24
14,304
Good Day, I am unable to find any support using Powerflex 525 in multiple with other Powerflex 525 instead i am only finding support with...
3,320
