Ethernet/ip communication between ML1400 and Productivity 1000
halosome
Dec 2005
bc
73
Hello,
I am trying to use micrologix 1400 Ver.A as adapter and a Productivity P1-540 as scanner, only Ethernet/IP is supported by ML1400 Ver.A.
It seems connected because from P1-540 I see the ML1400 Adapter name. But no data is able to transfer.
Can someone check my attached screenshot and tell me if I am correct in the program and settings at ML1400?
Thank you gclshortt! This is exactly what I am looking for!!
However he did not finished his post. I hope he could see his private message and finish his post.
unexpected problem happening when connecting said panel to a CJ2M-CPU35 via Ethernet (was replacement of broken NT21 via NT Link). The machine...
661
Hi All, I am having issues communicating between an Omron CJ2M PLC and a Lenze SMV Drive (with Ethernet Module). I have set up Network...
1,158
hello dear we have a problem with communicate with delta dop hmi and siemens s7-300 cpu . we use ISO ON TCP connection and AG-SEND and AG-RECV...
3,508
Hi All, I have a machine having Mitsubishi Q series (Q02) CPU. There is a dedicated software for machine which operate through PC (window based)...
1,996
Currently i'm working on a project where i use CPU 412-5H PN/DP redundant PLC with CP 443-1 ethernet module. My customer PLC is also S7-400H and...
2,365
