S7-1200 dynamic change of Profinet - OB(s) to consider
xzen
Jun 2006
Oslo
97
My current project has a Simatic S7-1200. It involves a robot with two different tools. Each tool has their own Profinet I/O-devices with different addresses and configurations. Changing tools involves disconnecting and connecting Profinet for the tool in use.
How do I handle the system errors that eventually will occurs during tool change, and operating with "missing" I/O-devises? Which OBs do I need to consider? Is it any different from S7-300? I have worked a lot with S7-300, Profibus and classic Step 7 v5.x. This is my first experience with the TIA portal and Profinet.
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
181
58
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
304
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
126
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
146
