Codesys sample program converting word variable into 2 byte variables
Feb 2012
UK
57
I am new to codesys programming and need some help converting a word variable into 2 byte variables.
If anyone provides the sample in Codesys syntax format, it would be great.
Thanks for the help.
bijt1:=WORD_TO_BYTE(woord);
bijt2:=WORD_TO_BYTE(woord/256);
some other possibilities are www.oscat.de
codesys.com forum
as long as you put codesys in the subject i will find you.
Consider an ordinary integer, represented in binary.
Dividing that integer by 2 shifts all the bits to the right by 1 position.
Dividing that integer by 4 shifts all the bits to the right by 2 positions.
And so on. Dividing by 256 shifts all the bits to the right by 8 positions.
So dividing the original value by 256 shifts the value so that the High Byte is now in the position of the Low Byte.
An example:
1234 decimal = 04D2 (hex).
1234 / 256 = 4.8203125. Truncate the remainder.
Result = 04 (hex)
ken you are correct i should have used SHR (lazy)
bijt2:=WORD_TO_BYTE (SHR(woord,8));
this one works exactly.
wordtobyte just takes the lower 8 bits from the word.
shr means shifting the bits 8 times to the right, meaning the low byte is overwritten by the high one.
and wordtobyte does the same as above.
and instru take a piece of paper and make it in bits with 0 and 1
Hello to all, can you please provide an example of obtaining a current working directory as a string in CodeSys? For example, during starting the...
228
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
224
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
450
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
136
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
228
