FactoryTalk View SE Redundancy
keithb
Aug 2002
Basingstoke, UK
53
Hi
I've just set a pair of redundant servers and 2 clients in FT View SE. No problems there, but how can I display something on the view clients to show which is the active server? I've trawled through the system and the manuals, but I can't find anything to do this. Any help appreciated.
Have you checked the knowledgebase?
I know there's an article out there, because we used it. It was written for CPR 6, but should still work.
This post is both a question (at the end), and maybe assist others with same issues. The detail on setting up FactoryTalk View SE V13 redundant...
1,408
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
105
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
73
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
88
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
78
