FactoryTalk View SE Redundancy
keithb
Aug 2002
Basingstoke, UK
53
Hi
I've just set a pair of redundant servers and 2 clients in FT View SE. No problems there, but how can I display something on the view clients to show which is the active server? I've trawled through the system and the manuals, but I can't find anything to do this. Any help appreciated.
Have you checked the knowledgebase?
I know there's an article out there, because we used it. It was written for CPR 6, but should still work.
This post is both a question (at the end), and maybe assist others with same issues. The detail on setting up FactoryTalk View SE V13 redundant...
1,369
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
43
222
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
143
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
194
