FactoryTalk View ME GOTO Display Bug
TheRooster
Jan 2022
USA
41
Hello all,
I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done many times, unfortunately it froze the whole program. I have restarted my computer and tried multiple times. At first I thought it may be because I had upgraded the version of this program, but I tried it again on a brand new file and it still froze. Anyone seen something like this before?
After this post I realized I should probably go download the most recent patch, still the same issue.
I guess I'll make the switch to v14. Hopefully that solves it
I agree, this sounds like the dialog is opening off screen. It "freezes" because you can't get to the dialog to close it. Do this:
  • Click the button to pick a display
  • Don't click anywhere else
  • Hold the Windows key down and press one of the left or right arrows a couple of times (while still holding WIN key)
  • This should bring the picker back to the main monitor
Thanks a lot! I am almost positive that's what it was because I just had the same window open half off a display in v14 and had to use the arrow keys to get it back.
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
144
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
18
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
49
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
223
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
139
