Micrologix500 to CCW conversion
Polo11
Apr 2018
Pe
Hi guys,
I was wondering if anyone could help me with a Logic conversion from PLC5 (Logix500) to CCW (Connected Components Workbench). Every time that I want to use the CCW conversion tool it gives me an error stating that there is data missing and should be fixed before continuing. The only thing that I can think of where I could have made a mistake is where I saved as to a .SLC file but ive searched the web and followed instructions but still get the same error. I dont want to re-write everything if there is a tool or someone that can help me.
I think we need to clarify what is needed.
So you want to convert a program that was wrote in RSLogix500 for a micrologix 1000 to CCW for a micro820 plc. (Is this what you are wanting?)
You can't just convert a RSlLogix500 program to CCW! You have to know what processor you are migrating from and to.
I think if you clarify this someone on this forum will be able to help.
Yes CCW 11 has been out for a couple of weeks, but it will be enhanced later in the year with the RSLogix500 conversion tool, at the moment it can only do any of the MicroLogix PLC's, not the SLC's.
As they add features they will become available for integration into CCW 11 without the need for a full download.
Alan
Note: manuals are now a separate download so CCW 11 is only about 2gig.
68
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
483
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
127
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
286
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
203
