Write to "current user" tag on PV+
robw53
Nov 2009
south yorks
515
Does anyone know if it's possible to write to the current username tag in a PVPlus from a logix controller?
I'm using a logix based security system for access control, but if it's possible to write to the HMI I can use the new audit function on V10 of FTVME.
Regards
Rob
Hello, I am fairly experienced programming and modifying existing FTView ME programs. I have also used FTView SE to make modifications to a...
121
63
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
128
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
155
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
188
