Requesting assist with learning how to write "call" for pressure and "make" pressure on booster pump with Zelio FBD?
JoeM61
Jan 2024
trenton
26
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when pressure is made.
Attached is the photo of where I've gotten so far. Any help with completing this rung as described above would be much appreciated.
EDIT: I should add that this is my first foray into analog using zelio function blocks. Very early learning curve here.
In case others find this in their search I think I found the answer which is to tie the analog input in to the Boolean function block just before it goes out to the pump output...so low pressure maintains a call to the pump unless or until high pressure make is reached which shuts the pump off.
does anyone have any insight on how to request specific data from an ATEQ Premier F leak test unit using a PLC? I have the ATEQ hooked up to the a...
1,405
Good morning all, Hope you guys are well today. I am looking for a DWG file which includes many common and even special types of electrical...
2,416
I have configured ControlLogix HART card but it's my first time working with compact logix HART card. Unlike ControlLogix card, in compact logix...
3,058
Hello everyone, This is my first time that I work with robots (at least with STYLE mode) I know that there are different ways to control a robot...
1,469
Hello all, I am putting together my first PLC/automation design at a company I recently started working for. I'm a EE (just graduated, little...
5,272
