wireless comms to PLC with DLink pocket router/ access point
I am trying to use a similar setup with a Hootoo TripMate Titan that i received. For the life of me, I am unable to get it to work.
My PLC is IP 192.168.100.2; The router is setup to give out DHCP addresses between 192.168.100.5-192.168.100.10. I changed the default IP on the router to be 192.168.100.1. When my PC connects wirelessly to the router I get the IP 192.168.100.5. With all of this setup, I am unable to ping the PLC at all.
Any help?
So you can ping the router but not the PLC? What's the ping result?
If there's a router status page, see if the PLC show up as a client. Also try to change the PLC outside the DHCP zone, say to 192.168.100.20
Any help?
Try setting the PLC address above the DHCP range, e.g. 192.168.1.20 - it might help.
The answer may be quite simple: some devices are configured to not respond to ICMP ping packets.
Hello everyone, I have read a few threads regarding setting up an AP to wirelessly communicate with PLC networks, but I have a unique question on...
579
Hi All, I am having lots of issues with wireless I/O and losses. Here is what the architecture is: Central - ControlLogix L62 processor. Remote 1...
3,908
I know that there are a few threads about this, but all I have read are not what I'm looking for. Is there away to communicate between the PC and...
1,898
Ok.here goes. I need to connect 2 by micologix1200 plc's,approximately 200m distance between them with wireless ethernet. Then connect a SLC505...
3,412
Hi, I am using 2 Xstream rf modems to monitor a micrologix 1200 on a moving platform, with no problems. I now want to do exactly the same with a...
1,858
