Codesys... and brands
userxyz
May 2002
any
2,768
Hi all,
Codesys and Beckhoff, Codesys and Mitsubishi, Codesys and Lenze...
I recently did a project with a C3200 controller from lenze and i700 drives. So I understand that Lenze uses Codesys, but what about Beckhoff and Mitsubishi... Beckhoff has Twincat and Mitsubishi has Worx, what ahve those todo with Codesys ?
Thanks in advance for clearify some things for me :),
Kind regards,
Combo
There's about 200 manufacturers that use Codesys. Some of the bigger players (Beckhoff, Schneider) use their own 'wrapper' around the Codesys IDE. There are advantages and disadvantages to this. Having to pay for it being one.
My preferred controller uses 'pure' Codesys; the IDE is a free download from the 3s Website. Clearly, the price is right.
My controller has the Runtime licence already installed so there's nothing to worry about.
Mitsubishi don't use Codesys. A few manufacturers speak about PLCOpen. My guess is Codesys are fully compliant.
And all 5 IEC61131-3 languages to choose from. There won't be many manufacturers that give (£0.00) you all 5.
And there's no manufacturer tie-in. You can see why it would be so unpopular with the established brands.
Pp
Thanks.
I quite like the idea of Codesys, but because they aren't usually seen much out in the wild, it's hard to have a grasp about any issues it may have.
I'll check that one out.
I use Wago, also a wrapper around CoDeSys 3. The language flexibility of IEC 61131/3 works for me, controllers are powerful, flexible and expandable I/O and our local Wago branch office gives good support.
I have only two Turck BL20-PG-EN - used as programmable RFID gateway.
Supports IEC 61131-3 (IL, LD, FDB, SFC, ST)
Beckhoff left Codesys. TwinCat 2 is Codesys 2, but TwinCat 3 is Microsoft Visual Studio.
ELAU EPAS-4 was Codesys 2 and the successor is Schneider PacDrive3 which is Codesys 3 and renamed SoMachineMotion. This is just slightly different from regular old SoMachine which is also Codesys 3 and they have mentioned they plan to combine the two into the same IDE for the next major revision.
B&R has members on the Codesys board and there are similarities between Codesys 3 and Automation Studio 3.x and 4.x, but Automation Studio is not, and has never been Codesys.
PLCopen is a different thing; it's a standardization on how to program servo motion control. Most Codesys platforms include it since the library already exists, but many non-Codesys platforms also have PLCopen available. Unfortunately, proprietary and unavoidable differences in how servo control operates platform to platform means that there can be notable variations, even in the standard functions. It's also way too granular and manual for modern programming. I'm seeing PLCopen fall out of favor quickly with PLC makers and more and more are providing alternatives that handle more of the drudgery automatically (single function block that powers the axis, jogs, homes, resets faults, etc). In PacDrive, you can't even access most of the robotics functions if you use PLCopen, so it was dead on arrival on a platform designed around easy robotics control.
What is maybe more interesting is not how many platforms do or don't use Codesys, but how many platforms us VxWorks as the RTOS. It's one of those unspoken things that a Zero-Day that compromises VxWorks would likely affect more than half of the active PLCs worldwide.
Correct me if I'm wrong, but for me Twincat seems some unholy combination of Visual studio and Codesys 2, where the IEC 61131-3 languages are still programmed with codesys embedded to visual studio.
A VxWorks zero day would probably affect half the embedded devices of any type worldwide, not just PLCs.
On the plus side, it's way better than everyone sludging their way through trying to secure their own proprietary thing. Most vendors don't have the resources for it.
On the downside, if there is a goof, wow. It's like the intel CPU stuff happening right now, it basically affects everything.
You are being too conservative... I think it's probably more than that. I mean, even fire detection systems use VxWorks.
I would also risk that a vast majority of shipping uses it too.
https://en.wikipedia.org/wiki/VxWorks#Notable_uses
I was being pretty broad when i said embedded, but yeah. Its everything from GE CT scans, to Cisco Switches, to SpaceX Dragon.
It almost feels easier to count devices that DON'T use it.
... the IEC 61131-3 languages are still programmed with codesys embedded to visual studio.
I agree. I have used both TwinCAT 2 and 3. It appears that TC3 uses Microsoft Visual Studio as a shell to incorporate what were separate programs in TC2 (System Manager and PLC-Control). They also use it to replace the PLC code editor. Underneath, it likely uses the same CodeSys engine and compiler. Indeed, System Manager appears almost the same in VS, just moved to VS windows and forms. Likely Beckhoff dove deeper in providing C++ coding for the PLC.
Moving to VS gave several advantages. In TC2, you must move back and forth between the 2 programs (build PLC code, link to it in SM then log-in, back to PLC to download code, ...). Most of that happens behind the scenes in TC3. You can also include Windows HMI code (VB, C#) within the same VS "solution", though not necessary and may add confusion.
What is maybe more interesting is not how many platforms do or don't use Codesys, but how many platforms us VxWorks as the RTOS. It's one of those unspoken things that a Zero-Day that compromises VxWorks would likely affect more than half of the active PLCs worldwide.[/QUOTE]
Actually, PLCOpen is a lot more than motion control. The point of the organization is to work towards standardization across controller platforms. It's a great organization and deserves your support. Probably the two most compliant IDE's are CoDeSys and MultiProg, but others are getting on the bandwagon. Of course the big dogs (Siemens and Rockwell) pay lip service to PLCOpen but have so much legacy in doing things differently I doubt they'll ever change...
Hi all, Is there a way to import POU's from ABB Automation Builder to Schneider EcoStruxure Machine Expert? They both run Codesys software. ABB...
1,925
Hello to all, can you please provide an example of obtaining a current working directory as a string in CodeSys? For example, during starting the...
230
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
226
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
450
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
137
