Panasonic Servos
mrtweaver
May 2007
Bloomsburg
329
I have some panasonic servos that have been obsoleted. In order to communicate with them I require cable DV0P0630 however i have google searched it, ebay searched it, and alas i can find no information on it. Have also contact panasonic due to age and being obsoleted they dont have a lot of details on it. Even if i can get a schematic or a lead on someone or someplace that may have the cable for sale. Also looking for someone or someplace that has the older panaterm software that will communicate with the XX series drive. The software panasonic sent me will only go back to the A, E, A4 and A5 but not X. THanks for any and all info.
Is it this one that GE Fanuc used to source from Panasonic?
The software for it may or may not work for you but worth a try. I have/had a cable somewhere too? Also there is a manual but all about the GE Fanuc version. DO473: SL Series Servo User's Manual I have been told the internals are identical.
Good luck!
RussB thanks for the information. It at least gives me a starting point. the drive def is the one in question just wondering why they only show pins 1 to 9 on the drive side when there is def 10 pins there. but at least with this it gives me something to look at. Now if i can find the cable or the end that fits the drive so as i can make my own cable then i will be set to test some things.
I found the cable (GE part no. IC800SLCS020) here are some photos that may help you locate one. (Or make me an offer.)
The connector has this markings:
Code:
[CENTER]DDK
DHF-10
Japan
[/CENTER]
hi everyone. i'm working now with panasonic PLC. The machine is OE, so I uploaded the file using FPWIN Pro 7 but when I open the program and try...
676
I am involved with the Panasonic FP7 for my final year project. I am doing a water distribution system and I want to use interrupt program for the...
741
Can someone tell me what I'm seeing here? I'm online with the FP2 and looking at some rungs with DT120 and DT124. Each are used twice and each...
1,749
I'm working with a Customer that has 2 Panasonic FP2-C2 units. I'm not exactly sure what this even is... Is it a PLC with motion control or just...
1,581
Currently working on a job for panasonic using FP-XH model PLC. I have finished my code and it seems to be working as expected (hopefully) :utoh...
1,792
