Converted a Panelview to Panelview Plus . Few Items did not convert.
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I converted a Panelview ( Panelbuilder 32 ) to a Panelview Plus ( FactoryTalk View ) and a few items did not convert correctly .
Panelview ( Panelbuilder 32 ) Message Display
Converted to a
Panelview Plus ( FactoryTalk View ) Multistate Indicator
What is the difference between Message Display and Multistate Indicator ?
Panelview ( Panelbuilder 32 ) Numeric Data Display
Converted to a
Panelview Plus ( FactoryTalk View ) Text Properties
Also , what caused a Numeric Display to convert to a Text Property ?
Thanks in advance ,
Good Evening ,
Converted to a
Converted to a
Thanks in advance ,
I did one of these conversions years ago, and I found a document on AB's web site which does take you through all that you need to do to properly deal with conversion issues like this.
I don't remember how I found it, so it will take some patience and persistence, but there is a document which provides some guidance.
Good Morning , I have a customer that has an old Panelview and an obsolete 1769-L35E processer . I need to replace the HMI , and I'm changing...
1,147
Everything works except alarms. The plc 5 uses a integer file and a number is moved there corresponding to the fault. 1-79 The text from PB...
1,149
Can I get somebody to convert a file for me from .RSS to .PDF? If you can please send me a message and I'll send you the zip file. Thanks-
1,293
I want to start using a VM for all my programming instead of my computer and wanted to see what is the best way to get my physical machine...
1,467
I currently have access to Studio5000 and RSLogix 5000 but neither gives options to read this RSS file. Can anyone convert to a PDF?
1,861
