Replacing an old Panelview , converted .PVA to FactoryTalk ME lost Runtime Config
Cydog
Feb 2018
Maryland
313
Good Morning ,
I have a customer that has an old Panelview and an obsolete 1769-L35E processer . I need to replace the HMI , and I'm changing the processor to a 1769-L33ER . When I converted the .PVA file to the FactoryTalk ME application I lost the Runtime Configuration .
I also need to replace the processor to the L33ER. Does that mean I need to create new shortcuts and drill down to 463 HMI Tags and create new connections ?
What would you folks suggest ?
Thanks so much , Have a great week.
You should be able to create a new shortcut that matches the shortcut name for your tags. Drill down through your communications to find the processor, apply the changes, and then start testing to see if it works. You shouldn't have to recreate or manually connect any of your HMI Tags.
Hi! i have a machine with a defective Siemens Cp341 modbus communication module...what im planning to do is replace siemens cp341 with a newer...
18
4,756
My DeviceNet skills are rusty and weak... so of course, an old, obsolete Reliance 400 HP VFD goes down and we're looking at replacing it with a...
5,001
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
105
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
565
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,174
