PowerFlex 700 and PowerFlex 700S
skhara
Dec 2006
WI
19
I am curious if some of you may be able to explain to me the difference between the PowerFlex 700 with
Vector Control and PowerFlex 700S. I know of instances of both having been used for almost identical
applications. Another engineer once mentioned to me that the 700S is better in winder control application,
but couldn't really explain why.
Hope you guys can help.
The S-for-System drive is much more complicated and powerful than the standard drive. You can use it with a DriveLogix controller cartridge, giving the controller direct memory access into drive tuning and command parameters.
In general I don't recommend 700S drives to users who are not drive system specialists.
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
162
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
130
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
362
Hello all, I was forced to replace a Powerflex 700 to a Powerflex 70 due to what is available. The digital input parameters (361-366) have a...
484
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,193
