Powerflex 700 / 70
AKVance
Nov 2023
Savannah, Georgia
Hello all, I was forced to replace a Powerflex 700 to a Powerflex 70 due to what is available. The digital input parameters (361-366) have a discrepancy in available selections. In the 700 there are sections for 39 & 40 (end of decel and end of limit). In the 70, selections 36-40 are labeled "reserved". The application is a hoist with a deceleration when reaching an upper or lower limit switch and end of travel at the next limit. The original 700 was programmed for parameter 363 (digital input 3) to selection 39 (Decel limit) and parameter 364 (digital input 4) to selection 40 (end limit). There are not options for these same selections within the 70 for parameters 361-366.
I am considering setting P364 to selection 4 (Stop) and P363 to a preset speed.
Any advice is appreciated.
-AKV
Setting decel limit to a preset speed is fairly equivalent. Setting end limit to a stop is not. The end limit in the 700 also enforced a .1 second decel for the stop. You'll need to set that input to also select the 2nd accel/decel, and have that decel set to .1. There is a fast brake stop and flix brake stop available in the 70, but I've never used them so best to consult the literature.
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
162
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
130
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
362
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,193
Hello Everyone, I have multiple machines that do the same thing, only the IP's are different. Some of the machines have AB drives while others...
1,228
