S7-414_3 (with CP443-1) communication problem with DASSiDirect
Jan 2010
Gothenberg
Hello All siemens expert
Here I have attached two file (1) about port setting (2) server setting. Again I mention all those in brief:
A. about SCADA computer:
(a) Hardware:
- Dell Power edge T300 (server)
- Dual port Ethernet card (Intel (R)PRO/1000 Server Adapter)
- Dual port Ethernet card (Broadcom Net Xtreme Gigabit Ehernet)
- Matrox Plug & Play multi monitorcard ( single DVI port) (M9120 Plus LP PCIe X1)
- 2 Monitor connected through a parallel branch cable to the single DVI port of Matrox card
(b)Software Installed on SCADA computer (server):
ComputerDescription:BioWoodServer
ComputerName:5028_SCADA
WorkGroup:WORKGROUP
-MS WINDOW 2003 R2 STANDARD EDITION ,SP2 V 5.2
-MS SQL SERVER 2005 V.090.3042.00
-WONDERWARE INDUSTRIAL SQL SERVER V 9.0.000
-WONDERWARE APPLICATION SERVER V 3.1 .000 3113.0001.0.0000
-WONDERWARE ACTIVE FACTORY V 9.2.0.0, 355.0112.0.0000
-WONDERWARE INTOUCH V 10.1 1412.0130.000.0000
-WONDERWARE S7SIMATIC DASERVER V 1.5 .100
-WONDERWARE SIDIRECT DASERVER V 1.5.100
-KEP SERVER FOR WONDERWARE V4.300.449.3-U
-OPC QUICK CLIENT V4.86.109.0-U
-OPEN OFFICE -ORG 3.1 V 3.1.0
- MATROX POWER DESK -SE V 11.12 .0000.0045
(c) Ethernet Connection
- cable: normal LAN cable 4 pair 24AWG UTP patch cable (for just testing purpose)
- PLC 1st port connected to Intel Ethernet card port 1
- Port Settings:
Address T ype :Manually Configured.
IP Address :192.168.0.113
Subnet mask :255.255.255.0
Default Gateway :192.168.0.2
(Network Connection Details)
Physical Address :00-15-17-B8-51-C4
Subnet mask :255. 255 255 .0
DNS Server :192.168.0.1
WINS Server :
(B) About PLC (S7)
(a) Hardware:
- Rack:0 Slot:1 =PS405 4A
Slot:2=CPU 414-3
Slot:3=CP443-1 (Dual Port Ethernet)
(b)In Simatic Manager/HW configuration/setting
Properties CP443-1 (R0/S4)
Under Tab: IP access protection
Activate web server = checked
Activate Access protection for IP communication= unchecked
Under Tab: IP Configuration
Set IP address in Properties-Ethernet Interface and dialog=checked
Obtain Ip Addres From DHCP=Unchecked
Set IP address in user program=unchecked
Set Ip address in different method=unchecked
Under Tab :Addresses
Start:8188
Address setting for lock/unlock with fetch/write speed send receive=unchecked
Under Tab :Options
Protection level: Notlocked
Activate Fast Switchover connection=unchecked
Interval=30
Disable UDP frame buffering=unchecked
Match case=unchecked
Under Tab :Time day synchronization
Activate NTP time day synchronization=checked
Time day sychronization on full minute=checked
Forward time day to station=checked
NTP server Address= 192.168.0.113
Propertise -PN-IO (R0/S4.1)
Under Tab:Genaral
Device Name: PN-IO
Support Device Replacement without exchangebale medium=checked
Interface: Type: Ethernet , Device number: 0 , Address 192.168.0.130, Networked : yes
Under "Properties":
Set MAC adddress/ use ISO protocol=checked
MAC address:00-0E-8C-BB-68_98 ( as printed on CP )
IP prototcol used=checked
IP address:192.168.0.130
subnet mask:255.255.255.0
Gateway: do not use router =checked
Subnet: highlighted on: Ethernet(1) , Properties: Name: Ethernet(1),
S7 subnet ID: 008A - 0053
Under Tab:Address
Interface;8187
Under Tab:Profinet
Send clock:1.00 ms
Max. allocation profinet IO:0.0 %
OB 82 /I/O fault task - call at communication interrupt=unchecked
Under Tab:Synchronization
Sychornization role: not synchronyzed
Name of sync domain:syncdomain -default
RT class: RT;IRT
IRT option:-----
Under Tab:Media Redudancy
Domain:mrpdomain-1
Role:Not node in the ring
Properties PN-IO-port 1(ro/s4/x1/p1)
Under Tab:Genaral
Addresse, port:8186
Under Tab:Topology:
Partner port :any partner
Under Tab:Options
Transmission medium: Automatic setting
Boundaries all are unchecked
For port 2 properties : almost as port1
(c) In Net Pro
Properties TCP connections:
Under Tab:Genaral Information
ID(hex): 0001 A050
Name :TCP connection1
Active connection Establishment=checked
Addresses: Local , IP:192.168.0.130 ; port (dec):2000
Remote,: 192.168.0.113 port (dec):2000
Under Tab:Options : Mode:Send/receive
Under Tab:Overview , everything is as befor , status :OK
I am not able to communicate with my PLC and little bit confused about the setting of ArchestraA IDE. Can some body guide me to about the setting of Archestra IDE or SMC and making the communications?
I am able to PING my PLC IP from the SCADA computre.
(C) About ARCHESTR A SMC
Under Branch: DA Server Manager/ Default Group/Local/Archestra A DASSIDirect.1/Configuration:
NodeType:$ROOTS ; Delimiter:
Global parameter:
Device group update interval:1000; Slow Poll Interval:60000,
Transaction to subcription ratio:2 ;Tansaction message timeout:60000
Server protocol timer :hide ; Diagonestic blockage size:20;
Max qued transcation: 75 ;Maximum qued update: 1;
DDE/suite link time tick:50; pock mode: optimazation mode;
case sensitive=unchacked; device group cache=unchacked;
Simulation mode=hide; systems items: checked ;
Unique device group=checked
// ... /Configuration/BioWood-PortCpS7_0000: ( rename :New_PortCpS7_0000 )
BioWood-PortCpS7_0000 parameter:
port type :TCP/IP (hide)
// ... /Configuration/BioWood-PortCpS7_0000/BioWood_S7Cp_0000 :
(rename:New_S7Cp_0000)
Under Tab:BioWood_S7Cp-0000 parameter:
Node type:S7Cp , Deliemeter:
Processor type:S7 PLC (hide)
S7 connection;
Network Address:192.168.0.130; Local TSAP: 1 - 0 ;
Remote TSAP: Remote rack No: 0 , remote Slot no:2 ; Connection resource:3
PLC connectivity:
Verify PLC connectivity when no item is subscribed=checked
Frequency in seconds to varify the plc connectivity=60
Reply time out:15000ms ; connection time out:30000
Alarms and events: Dissable all=checked; enable alarms=unchecked;
enable events=unchacked
Under tab:Devicegroup:
Name: S7PLC, update interval.1000
Under tab: Device Item: (empty)
(D) in ArchestraA IDE
Deployment/BioWood_WinPlatform/BioWood_AppEngine/BioWood_DDESuiteLinkClient
UnderTab:Genaral
Server Node:5028_SCADA
Server Name:DASSIDirect
Communication Protocol:Suitelink
UnderTab:Topic
Topic:SLPLC; Scan Mode:ActiveOnDemand
Mostafa
Topic:SLPLC
I take it this is a typo and your topic is actually S7PLC ?
I know its obvious, but I've got to ask... have you activated the DA server?
Hello Team, I have an 6ES7414-3XM05-0AB0 CPU and someone wants to offer me 6ES7416-2XP07-0AB0 CPU as replacement part. I need to know if there are...
1,953
I have citect scade project in pc station connected to plc 414 and working fine. The pc station is getting very old and wold like to swap it with...
31
5,933
Hi These questions are also created at Siemens network, but maybe there are more knowledge in here. :yeah...
2,507
I have an S7 414 with a 1MB card. The line has been running fine but I needed to added some analog inputs to one of the ET200SP profinet modules...
5,078
Hey all, I have been looking through the forums and many other places, and while I have found a lot of information, nothing seems to specifically...
1,934
