archestra gr node
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am trying to connect to my archestra gr node from my laptop, gr node is running on a server, I am using the same user account set up under common/change user account and when I start archestra I can click on the search block and it finds the gr node I want to log onto and is finds the galaxies under that node, but when I try to connect I get cannot connect check logger, the logger say that it is a fire wall but I turned the fire wall off on my machine and on the gr node, same results, anyone ever seen this result? any clues on what I can check? Ping works fine.
always fun this.
a few things to check off the top of my head.
1. make sure your laptop's user account has the same password as your network account utility user on the server.
2. Try switching password protected sharing off on the server under network and sharing center.
3. check the dcom settings on the Server (dcomcnfg.exe) make sure the user account has access permission on the server.
4. Make sure the RPC(Remote Procedure Call) Service is running on the server.
At my wits end with this. System was running fine. First came a domain migration, which screwed up the User List, creating duplicates under the...
2,994
Hello everyone, I'm having some trouble deploying one of my nodes. Situation: A Server is working with 4 clients. What i'm trying to do is add...
3,820
Hi all I just reformated one of my View Nodes on archestra and reinstalled every thing on my machine.Every thing is working fine but cant seem to...
2,033
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
130
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
135
