Siemenes Analog Input card SM 331 failure frequentely
Pramod Patil
Dec 2008
nashik
25
Hi All,
I am facing one problem for siemens SM331 AI card . i am connect PT 100 as input for channel 0 & 1 . but this card failes with in week or 10 days reguraly. after failure of card nothing found abnormal in circuit. please any one can help me on this issue . thanks in advance.
thanks for reply card failure means it does not shows temp. related to this card on HMI . and if this card replace with new card its work properly.
what kind of enviroment is it in?
Some gases can increase the corrosion which could lead to failure. Also voltage spikes can fry the card.
Dear OjZor,
thanks for reply.
but we give PT 100 means resistance as input to card .still there is any possbileties of short ckt. or Voltage spike ?
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
113
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
126
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,136
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
258
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
119
