2D Data Matrix - separating out data
tspisak
Aug 2005
Corning, NY
72
Has anyone read a long 2D data matrix (200+ characters) and separated out the data in to different fields (~twenty)?
I plan on adding a comma to indicate the start of a new field but I don't know where to start programming. The data is a recipe so the data types for each field will stay the same from code to code but the length will not (long and short strings).
I am using a Keyence SR-651 barcode scanner connected to a A-B CompactLogix processor via Ethernet IP.
Any tip on getting started?
What kind/brand of 2D data matrix readers are the easiest to set up and communicate with CompactLogix PLC? I'm looking to install and setup...
2,204
116
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
65
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
48
257
