Proximity/Photocell 4-20mA output for position
geniusintraining
Jun 2005
SC
8,303
Anyone know of a semi long range prox or photocell with a 4/20mA output? I need to detect the position of a object (plastic ball) in a tube, the tube will be about 8-12" long and need to detect the ball for about 6-12 inches of travel
I think they are out there but can find any
Definitely better priced, thank you
Just ordered the UK6A-D2-0A from AD.... for under 100 bucks worth a try
Thanks John, yes it seems if you need to fill out a form so get the price it may be out of my budget scope ;)
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
346
Hi Members, Currently, I'm working with Motor Generator speed measurement. Just wondering if possible or not my integration system for speed...
2,092
Hi please need your help, can I install the Proximity Probe 21508-02-12-05-02 Bentley Nevada on the drive 1442-DR-5850 from Allen-Bradley using...
2,164
Newbie here - I'm working on a project for a class and experiencing problems with getting my proximity sensor to activate a solenoid. I'm using...
3,399
Does anyone have a suggestion for some kind of proximity sensor that would detect if an object is sticking out of a cup? A stationary cup, so it...
3,306
