Parameter Upload - PowerFlex 700 VC - RIO - 20-COMM-R - SLC 5/03
Cranford
Jan 2020
Orlando FL
I have a Powerflex 700 VC (actually a number of them) all connected via RIO using a 20-COMM-R back to an SLC 5/03. I need to install a replacement drive and want to upload all of my drive parameters to it (I have the original .DNO file) I have CCW but not the older drive software (don't know the name) but believe it is now freeware, not sure if I need to use that on this older drive?
Can I use CCW and connect through the PLC as I would do with RSLinx/RSLogix or do I need another serial device to see the drives?
I really do not want to have to input all the parameters in manually!
Any help would be much appreciated!
thanks
Austin
SLC processors can't bridge like Contrologix processors. You will need a 1203-USB to connect your laptop directly to the drive.
The software you are thinking of is DriveExecutive.
To my knowledge the 1747-SN and RSLinx could provide "passthrough" upload/download functionality to PanelView Standards, but not to any SCANPort or DPI based drives.
For a PowerFlex 700VC, I agree you'll want a 1203-USB and DriveTools/DriveExecutive.
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
338
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
84
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
465
Hi Everyone, I am trying to add a constant value (such as a string) into the parameter file. I put the string in " " but it does not work. would...
204
I confess, I always have a little frustration trying to accomplish tasks in CCW that are simple in Studio 5000. My latest task is with timers...
487
