Factorytalk SE parameter file
sayahan2003
Jun 2006
Calgary
185
Hi Everyone,
I am trying to add a constant value (such as a string) into the parameter file. I put the string in " " but it does not work. would you please let me know what format I need to use to be able to pass the string?
thanks
Hi Everyone,
thanks
Create a memory string tag, write in the initial value in the tag configuration, and pass that tag as a parameter.
You can't use spaces in strings. I don't know the reason why, I just know you can't.
For example:
#1="This does not work"
#2="ThisHoweverDoes"
As a solution that will break the minute someone other than you comes along, or you just a few months later, you can use "no-break space": keystroke Alt+0160
Hi All, I am looking at an existing FactoryTalk Studio program and have come across in the parameter file :- #10=/::Alarm0_28.Disabled I...
1,151
Hi, Using factoryTalk view studio ver 6 to work on a HMI project. This project is been created by third party vendor and not able to access it...
2,067
Rockwell converted a running IFIX system to FTView SE for a customer. (By the way, NEVER have them do this. They sell it as a 90% complete...
2,623
Hi, I have a configuration display that will be used for 80 devices. I will create and use 120 parameter files. Each parameter file will be...
2,277
Is there a way I can pass a string with spaces in the parameter file? I want to do something like this: #1=Water Makeup
14,760
