rtragle Member R Join Date Jul 2015 Location Bakersfield Posts 19 Aug 6, 2015 #1 Is there a way I can pass a string with spaces in the parameter file? I want to do something like this: #1=Water Makeup
rtragle Member OP R Join Date Jul 2015 Location Bakersfield Posts 19 Aug 6, 2015 #2 I found a solution, but I was hoping there is a better one... http://forums.mrplc.com/index.php?showtopic=15200 Basically, I'm using the No-break space from the character map for arial font. It works, but I have to Ctrl-V everytime I want a space
ASF Lifetime Supporting Member A Join Date Jun 2012 Location Australia Posts 3,921 Aug 6, 2015 #3 Have you tried surrounding the string with quotations? #1="Water Makeup" I won't promise it'll work but that would be the first thing I'd try
MarkNightingale Lifetime Supporting Member + Moderator M Join Date Sep 2010 Location In The VAT Shed Posts 744 Aug 7, 2015 #4 Press down the alt key and hold it, and then type in 32 on your numeric keypad. Cheers Mark
Bering C Sparky Lifetime Supporting Member Join Date Mar 2014 Location Bering Sea, Alaska Posts 1,117 Aug 7, 2015 #5 MarkNightingale said: Press down the alt key and hold it, and then type in 32 on your numeric keypad. Click to expand... Nice, I love learning all these little tricks. (Thanks for that) Here is a link to more ALT+ Tricks http://usefulshortcuts.com/alt-codes/punctuation-alt-codes.php
MarkNightingale Lifetime Supporting Member + Moderator M Join Date Sep 2010 Location In The VAT Shed Posts 744 Aug 7, 2015 #6 This is the one I use. http://tools.oratory.com/altcodes.html Cheers Mark
DrBuzz Member D Join Date Jun 2022 Location Vancouver Posts 1 Jun 14, 2022 #7 Hi Folks, Alt+3+2 (on the number pad) produces a regular space and FT View will recognize it as a space and throw a syntax error. Try ALT+0+1+6+0 (on your number pad) to product a space that will work. Cheers
