Factorytalk passing string in parameter file
Have you tried surrounding the string with quotations?
#1="Water Makeup"
I won't promise it'll work but that would be the first thing I'd try
Hi Folks,
Alt+3+2 (on the number pad) produces a regular space and FT View will recognize it as a space and throw a syntax error.
Try ALT+0+1+6+0 (on your number pad) to product a space that will work.
Cheers
Hi guys, A dumb question, but is it possible to pass values to tags using parameter files in Ftview SE ver 11? TIA
1,477
Hello, I am trying to modify a working program that uses parameter files for the different control items in the system. So for PID Loops there a...
8,220
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
46
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
82
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
69
