iFix Lable Caption Refresh
asterof
May 2007
Califonia
554
I am trying to set the caption of a label
before doing a test of a connection to an SQL server
Private Sub SQL_Test_Button_Click()
Const NVGeneralBottleRecordConnString = "Provider=SQLNCLI10.1;Data Source=FASDB\FAS_MSSQLSERVER;Initial Catalog=BatchRecord;" & "User Id=SQLusrVb;Password=SQLusrVb1!"
Record_Str.Caption = "Please Wait, testing connection to SQL Server"
Record_Str.Refresh
TestConnectionToSqlServer (NVGeneralBottleRecordConnString)
End If
End Sub
However the caption is not updated until the call to the
TestConnectionToSqlServer has timed out
How do I get the caption to update before the call
Your problem is that the VBA code is running in the same thread as workspace is using to update the UI. Put in another way, the UI will not be updated until the function is done executing or you manually tell VBA to process other events. You can tell workspace to process other events by adding a DoEvent after setting the label caption. Please note that DoEvent can make workspace crash if used incorrectly (it's fine in this case) so try not to use them too much.
Have you considered using VisiconX to connect to your database? IMO it will be a cleaner and solution without any - or very little - custom code.
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
68
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
180
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
178
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
757
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
476
