iFix 5.5 start up screen
TheLeaner
Mar 2017
Michigan
Hello,
I have a an iFix 5.5 client node that talks to an iFix 5.5 SCADA server. Every time I start up the client it displays an empty screen. I have to go to the ifix icon(file)>> open >>browse screens.
How do I set up an automatic opening screen. Please note I only have RUN TIME license. So it won't let me switch to workspace mode to select the opening screen.
E.
You can pull the dongle and restart the client to get into development mode. This has a two hour restriction on time limit and has to be restarted after that. Use ALT-W to switch workspaces. You can also tap ALT and it brings up the menu bar. At least then you can explore to find the option you are looking for.
You can also start-->run and type CMD
cd into the ifix directory and type "fix32.exe /t" to open in trial mode without removing the dongle.
iFix is writing 0s to analog & digital outs after importing tags and restarting services. We don't see outputs in the ALM files, but it...
910
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
64
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
180
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
178
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
755
