Micrologix 1100 RSLinx issue
wvernon
Jan 2008
South Carolina
Hello, first post.
I can't seem to get the Micrologix 1100 to show in the RSLinx browse window when using the Ethernet/IP driver.
Strangely enough, I can upload, download, and go online with the controller, but it shows in the browser as an unidentified device.
Any suggestions?
You may need to manually add the controller, NOT the eni device. RSLinx usually finds the ENI adapter and then you need to delete it. I tis strange you can ul/dl to/from the controller. Sometimes if it ain't broke don't fix it I guess.
Where did you see he had an ENI?? An 1100 doesn't need one...
I've got RSLinx version 2.42.00(build 18) and RSLogix 500 vesion 6.30.00(CPR 6) and i am unable to get comms with the micrologix 1100.Have i got...
8,257
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
522
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
190
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,193
