RS STUDIO runtime file
Jan 2010
hyderabad
21
Hi friends i am using rs studio run time PC .Wen i am open run time file it comes unable save the backup file no load any file then i enter the OK unable to load the file.
Please suggest me how to open the run time file
more info
You're going to have to give more details than that. Specifically, if you can submit the exact error message, or error message number, we might be able to help you. Also, I would recommend the AB knowledgebase on their website. My help method would be taking your info, and searching there first, so you might find the problem yourself.
ive encounted this problem before, when you save the file and the dialogue box comes up, change it from version 5.0 to 4.0 or which ever firmware you panel runs. remember PV's are backward compatible.
another one could be if you have changed anything for example opened up rslinx enterprise within FT View studio, there is a verify button towards the bottom of the screen, verify then click ok and it will close that dialogue box.
like russ mentioned post a bit more info and we mite be able to point you in the right direction
Rob
Hello all, can anyone shed some light on the following; I have FT View studio enterprise 8.20 running on my development PC. I would like to...
4,552
Using RSView Studio V3.2 for the first time in 4 years. When trying to create the runtime file, an error occurs "Cannot save database" and the...
6,980
We have RSView Studio for ME cpr4 Last project I have worked with was about one year ago. Now when I tried first time to create the runtime file...
17
42,815
I'd like to have a display in my view studio runtime show the current ip address of the panelview. I know how to fetch the plc ip address but I...
1,283
Hello, In FT View Studio ME (v12); When I go to restore a runtime file currently in use on a PV+7 I receive the error in the attached photo. It...
2,171
