holyhobgoblin
Ok found the Technical Reference manual for this controller, never seen any thing like it.
I've attached it for people interested at looking at it.
I've spent 5 minutes looking through it, found this command and if i read it correct it should simply tell you the position.
Command: TP - Tell Real Position --
This command reports the absolute position of the servo. It may be used to monitor motion during both the Motor On (MN) and the Motor Off (MF) states. Related Commands: TT, TO
or try
Command: TT -- Tell Target Position --
This command reports the current target position of the servo. This is the absolute position to which the servo was last commanded to move. It may have been specified directly with the
Move to Position (MP) or Move Absolute (MA) commands or indirectly with the Move Relative (MR)command. If the servo axis is in Velocity Mode (VM), then the target position will track the current optimal position (or that which is reported by the Tell Optimal (TO) command).Related Commands: TO, TP
Mr Holyhobgoblin
or try
Mr Holyhobgoblin
