Help with AB message
cncsparky
Dec 2014
Ks
99
Having trouble getting a message working. Searched here but didn't find what I was needing. Locally connected controllers on the same subnet and with the same mask(255.255.255.0).
L33ER <- Read -< MLX1400
Reading a Float in MLX1400 to a Real Float in compact.
Source Element : F8:0
Destination : FilterData[0]
# Elements 1
Was getting connection errors but seems to have been resolved with the following path: 2, XXX.XXX.XXX.XXX, 1, 0
Now getting 'Unsupported Service Requested' fault. Does this mean my path is OK now?
Am I able to message read a Float into a Real Float tag? I Read a post that suggested I may need to COPy the Float in MLX to an integer file. Is this what I need to do, then message the integer to the Compact?
Thanks for any help!
Thanks Garry. That was enough to get me going.
I only had to remove the , 1, 0 at the end of my path. Messaging the floats works, also.
Thanks for any help! I can usually figure these out, but after an hour of misses I don't have any more tricks up my sleeve. I've read some great...
1,341
When you are compiling (translating in Red Lion parlance) user defined programs - what does "Unexpected End-of-Text" error mean? It is at the END...
1,814
I need some help understnading an error message I'm getting when testing an application. data table I1:1-I1:13 in slc at station 1 serial-DF1 is...
3,382
Hello, I'm trying to read a parameter from a Power Flex 525 drive to monitor output current in order to detect a jam condition in carousel filler...
3,713
