Help with Red Lion Error Message
Brian@HCI
Nov 2016
Kansas City
19
When you are compiling (translating in Red Lion parlance) user defined programs - what does "Unexpected End-of-Text" error mean? It is at the END of my program and I am NOT seeing what type of 'C' syntax error that would cause this.
Any ideas?
Brian
Absoutely correct!
Thanks Rube......
I had an unusually LONG switch statement that had the opening "{" but did NOT have the closing "}" WAAAY at the end of the program.
That did it thank you very much.
Brian
Worth noting that you can also get that error when you're missing a semi-colon, though it usually will tell you that it's specifically talking about a missing semi-colon.
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,124
I'm working on a Graphite that is continuously looping through the start up sequence then stops and shows a page that says "system could not...
4,918
Hey guys, I was wondering if a G303 Red Lion HMI can be used as a scanner? I am having trouble finding information on this. Thanks
1,401
Hello everyone, Brian the Newb here again regarding Crimson 3.0 and J1939 CAN protocols. I had searched the archives and I DID find a couple of...
2,994
I have a cardboard baler that uses the Red Lion CL05 interface to control bale size, wire twists and a couple other things. It is showing invalid...
2,814
